Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - How to make right side turn signals and brake lights work on 75 TA
Old 08-07-2012, 07:27 AM
dogwater dogwater is offline
Last journal entry: Still running strong
Do the temp. Ground wire first ,thats easy,if that doesnt help use a vlotage meter,be sure to set it to DC and start checking for voltage.Behind the horn botton inside the colum theirs a white plastic thing that the turn siganl lever switchs back an forth,it been a long time since Ive messed around with one but it might have contacts on it,they may be broke off or not making contact.
The Following User Says Thank You to dogwater For This Useful Post:
walt03 (08-07-2012)
