How to make right side turn signals and brake lights work on 75 TA - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-06-2012, 10:23 PM
This 75 Trans Am has the left side front and rear turn signals working.
On the passenger side, the front works but the back doesn't and all bulbs check out.
Also, the passenger side, the brake lights don't work if this is part of the same problem.
Switched around fLASHER RELAYS from AND STILL THE SAME THING. Relays don't make any difference.
I'm scratching my head on where to go next.
Can anyone help?
Thanks
Walt
Old 08-07-2012, 04:08 AM
EOD Guy's Avatar
Sounds like bad grounds...... run a temp ground with a piece of jumper wire from the body of the light socket to a clean bare spot on the frame etc..... if it works well just a little cleaning etc...
The Following User Says Thank You to EOD Guy For This Useful Post:
walt03 (08-07-2012)
Old 08-07-2012, 06:27 AM
Last journal entry: Still running strong
Do the temp. Ground wire first ,thats easy,if that doesnt help use a vlotage meter,be sure to set it to DC and start checking for voltage.Behind the horn botton inside the colum theirs a white plastic thing that the turn siganl lever switchs back an forth,it been a long time since Ive messed around with one but it might have contacts on it,they may be broke off or not making contact.
The Following User Says Thank You to dogwater For This Useful Post:
walt03 (08-07-2012)
need wiring diagram for brake lights turn signals on 77 Chevy C30 truck mike 96 ws6 Electrical 5 09-04-2011 04:30 PM
Turn signals to brake/running lights conversion (motorcycle) weirdbeard Electrical 3 08-08-2010 03:16 PM
1963 cadillac brake lights and turn signals Help Please colwoodshane Electrical 6 03-07-2010 01:24 PM
Brake light/turn signal lights wont work together ChevyForever Electrical 1 10-04-2004 01:19 PM
dash lights and turn signals - again SteveMach1 Electrical 2 12-13-2003 10:22 PM
