how to make wind wing frames ??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-15-2010, 11:56 AM
bobjob's Avatar
I have a 48 dodge town sedan with a chopped top.. I am having trouble finding wind wing frames for it to modify.. need 4 ,, tried the dodge site ,, none available.. how can i make them from stainless channel ?? where can i get some made ?? or where to get the channel ?? i'm at a stopping point without them....
Name:	R1- 3 (Medium).jpg
ID:	44537   Click image for larger version
Name:	R1-20 (Medium).jpg
ID:	44538   Click image for larger version
Name:	R1-14 (Medium).jpg
ID:	44539   Click image for larger version
Old 03-15-2010, 12:06 PM
Why make them at all, maybe run one piece windows?
Old 03-15-2010, 12:23 PM
bobjob's Avatar
can't on rear..not enough room ..and this body style is quite rare,, wind wings front and rear really makes it unique....
Old 03-15-2010, 02:04 PM
what if you use a 57 Chevy rear window goodies , they roll front down first and go at a tilt as they bottom out .
just a thought ?
Old 03-16-2010, 10:13 AM
Shabby chic sheet metalshaper
If you have the time, you could make them from stainless. A hammerform would do the trick. You could make the hammerform from solid square stock, clamp the stainless on it and hammer the flanges over. Not easy!
John
Old 03-17-2010, 04:13 AM
Why not make them out of mild steel square tubing? You can cut, weld, and bend until you get the right shape, then cut out the inside side to make channel out of it. Then chrome plate it as that's probably what originally came on the car. Or for something different you could paint them body color.
Old 03-17-2010, 11:28 AM
bobjob's Avatar
steel is a option,, i guess that i will have to try and figure out something .. that's why im here .. looking for options.. i have to have them to make it look right ...and i can't make windows work without them ... not enough room inside ..
Make a poor man's billet 3rd brakelight. cboy Interior 11 06-01-2009 09:09 PM
How to Make a good Pattern From a Bad Original DanTwoLakes Interior 6 05-25-2009 11:31 PM
is it pssible to make a 283 into a 327 stroker? talon0713 Engine 43 01-09-2009 12:19 AM
What car (make and model) can be use to place a Model A body? Fortingo General Rodding Tech 7 05-10-2003 04:25 PM
I have a confession to make....... 454impala69 Transmission - Rearend 4 05-06-2002 05:19 PM
