how many amps? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-10-2006, 05:26 AM
how many amps?
hey all. how many amps (roughly) does a after market air conditioner use? i have a 63 buick special with a 215 2v. someone suggested a 94 amp. i was told this was over-kill for my application. the car came with a 55 amp alt. i picked up a parts car with after market air which also has a 55 amp alt. i drove this car 150 mi home while running EVERYTHING (including air) and it seemed to do fine. would the 55 amp do the job (it will only have power steering and air as well as a 100 watt amp)? would it take a 63 amp do the job? thanks for any suggestions!
keith (who doesn't know much about amps/electricity and such )
Old 09-10-2006, 05:44 AM
poncho62's Avatar
Wiki Edits: 5
55 to 63, thats only 8 amps. In electrical, as with anything, overkill is probably better. Don't know whether you need it or not, but it can't hurt.
Old 09-10-2006, 06:00 AM
docvette's Avatar
Wiki Edits: 12
Doc here,
Just because the alternator is rated at 100 amps, is not what the output will be 24/7 365...
It is dependent on the regulator demands from the system load..
If it needs 35 amps it will produce that and shut off when the demand is met. If it needs 90 amps the same logic applies.
No such thing as overkill..HOWEVER there is such a thing as "Jump start"...
To find your actual draw you need to do a load test under the worst case scenerio..Everything running electrical..including brake lamps,backups, interions..turns or 4 ways..stereo Full volume...everything full on..Take that figure and go 25 or 30 amps above (for headroom) and you'll be just fine..
Whatever the upgrade BE sure the wire gauge and fuse link are proper for the new draws..
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 09-10-2006, 08:24 AM
how many amps
yes, i love overkill myself but i am trying to not OVERKILL my wallet ! i would like to go with what i need and not "more" than i need. what i am really interested in is how many amps (roughly) would a aftermarket air draw. i have ALL manuals for my car and they don't give a clue for my question. btw a 63 amp is 50.00 less than a 94 amp. if i NEED a 94 fine, but if a 63 would work why waste the
extra 50 bucks. my son ordered a new fluke meter that should be in friday (at which time i will do a load test) but till then i am just curious how many amps (roughly) the air would draw. since the guy that will supply the delcotron will take two plus weeks i wanted to get a headstart and order it today instead of waiting till friday to do a load test. i wanted to make sure i am not buying more than i need. since the parts car with after market air i drove home (140 mi) worked fine with a 55 amp (with everything running), i was thinking that a step-up to a 63 might be fine. just trying to be frugal (cheap?) before i make a purchase. oh well, if need i will just wait till friday and do a load test. thanks.
keith (who is just doing his homework)
Old 09-10-2006, 08:26 AM
how many amps
Originally Posted by docvette
Doc here,
Just
Doc
thanks Doc. i will make note of this
keith
Alternator only putting out 12 amps Kamino64 Electrical 14 04-14-2006 04:07 PM
TIG welding will's53chevy General Rodding Tech 29 12-21-2005 01:38 PM
Amps draw on 3.8 Taurus electric fan? macx Electrical 14 11-18-2005 09:07 PM
Headlight amps and fuse size? JohnTN Electrical 6 07-13-2005 07:43 PM
computer amps NorthStar Electrical 1 03-02-2005 09:05 AM
