LinkBack | Thread Tools |
Simplicity- it will likely never break or be the cause of an overheating problem due to its failure.
They're cheap to make, light weight, not particularly RPM limited, and in cases where they give sufficient airflow there's nothing particularly "wrong" w/them- although a correctly sized fan using a clutch will use less energy in many cases and cool just as well if not better. |
What i'm trying to get at is i'm interested in possibly using an engine for stationary power use. So the engine would only turn 600-1000 rpm all the time.
Would a clutch fan work well in this situation as opposed to a fixed blade? Considering that the rpm is rather low would the supposed energy savings from a clutch fan be negligible at this point? i'm thinking fixed would be simplier and wouldn't really consume all that much power at 650 rpm? |
If the engine is at idle making little power,almost any fan with a decent rad is more than adequate.If the engine is stationary then any auxilary fan will work fine. When a car is on a dyno making full power a small aux fan is usually placed in front of the car with no problems.You could probably use a rad from a big truck and no fan. A dimple core rad with a small fan. A water reservoir,,,,
| Tags |
| fans, general motors |
| Mechanical fan options | tjet | Engine | 7 | 01-31-2012 09:42 PM |
| mechanical fan blades | THERACER | Engine | 3 | 07-05-2011 11:41 AM |
| can fan blades in a small house type fan go flat? | matt167 | Off-Topic | 4 | 09-15-2009 04:34 PM |
| Mechanical fan spacer for GM | dirtinla | Engine | 1 | 06-11-2009 03:00 PM |
| Electric or Mechanical fan? Which do you prefer? | Z-Money Pit | Engine | 13 | 11-15-2005 05:44 AM |
