Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - How many leafs would you remove?
Old 09-21-2010, 08:16 AM
MARTINSR MARTINSR is offline
Originally Posted by Frisco
Unless you 'C' notch or 'Z' the frame, it will be fruitless to remove any leaves from the spring stack. It looks like you only have about 1" clearance between the rear axle housing and the bottom of the frame at the present time. Removing any leaves will cause you to bottom out against the frame.
LOLOL, That is what I was thinking! Heck, remove ONE and it will likely be hitting the frame!
