How many leafs would you remove? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-20-2010, 05:38 PM
car enthusiast
Last journal entry: Future Build: 1927 Dodge 5 window coupe
How many leafs would you remove from this spring set up?
Old 09-20-2010, 05:47 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Depends on what you are working on and what you are shooting for.
How low do you want to go?
Cole
Old 09-20-2010, 05:48 PM
I dont know what you are hauling,but I would remove 4 or 5 leaves from each spring.You've got plenty.
Old 09-20-2010, 05:54 PM
car enthusiast
4 or 5 sounds good. I don't have any plans for haulin anything, it is strictly a rust rod....The way it sits right now, i can bounce up and down on the back of the truck and it will not move at all.
Old 09-20-2010, 06:08 PM
eloc431962's Avatar
Wiki Edits: 37
If thats the case then i would start experimenting with it till i got what i wanted.JMO
Cole
Old 09-20-2010, 06:14 PM
adantessr's Avatar
'23 T-Bucket Pickup
Last wiki edit: Troubleshooting ignition Last photo:
Wiki Edits: 3
From what I have seen on your other posts of this rig, I would take out all but the four longest leaves and just set it back down on it and see how it feels and then add more if you need to, and then measure for new center bolts and u-bolts . You have very little weight here and I'd be surprised if you need more than the four longest leaves.
Old 09-21-2010, 07:16 AM
cboy's Avatar
Last journal entry: Finished
Just a side note for those swapping around leaf springs. It's not just the number of leafs you remove, but which ones. Removal of the shortest leaf is going to soften up the ride more than removal of the next to longest leaf...and so on.
Also, one needs to do some dancing to get both the ride and ride height you want. Engine weight and position, along with other factors, makes every car different. You may need to first add/subtract leaves until you get the ride firmness you want and then add or subtract blocks or spacers to get the car back to the ride height you want. Depending on how particular you are, this can require a good deal of experimentation.
I've been fiddling with the quarter ellipticals on my sedan delivery all summer to perfect the ride and have ended up with three leaf stacks (using F-100 springs) to soften the ride both front and rear. However, to do this I needed to use 6 degree wedges (normally used for setting pinion angle) in order to retain the ride height I needed.
Always learning...and sharing what I've learned. The Scratch-Built Hot Rod.
Old 09-21-2010, 07:18 AM
Frisco's Avatar
Glad To Be Here
Unless you 'C' notch or 'Z' the frame, it will be fruitless to remove any leaves from the spring stack. It looks like you only have about 1" clearance between the rear axle housing and the bottom of the frame at the present time. Removing any leaves will cause you to bottom out against the frame.
Old 09-21-2010, 07:42 AM
NEW INTERIORS's Avatar
Set no limit's on yourself
I would take out all ''but'' the top four.. You ''will'' Have to c-notch the frame, There's no getting around it..
Old 09-21-2010, 08:16 AM
LOLOL, That is what I was thinking! Heck, remove ONE and it will likely be hitting the frame!
Old 09-21-2010, 01:49 PM
adantessr's Avatar
'23 T-Bucket Pickup
Wiki Edits: 3
I am pretty sure this is the same guy that was on here on a different post asking about c-notching the frame and if it is he has that part taken care of. He included pictures. This is a before picture. How about it Cheyenne ?
Old 09-21-2010, 03:23 PM
This pees people off when I say to do this but it works great and last a long time: Take out all of the leaves except the main leaf. Notch the frame for clearance. Make up two radius rods, one for each side, with hymn joints in both ends. Mount these two rods close to the same mounting pivot point that the front eye of the main leaf spring pins mount too. Weld a bolt on the side of the U-bolt plate and mount the other end of the radius rods there. With only using the main leaf on each side, these radius rods will keep the axle from winding up under hard acceleration and braking. Now that you have done all of this put air shocks or air bags on the axle and adjust the ride hight where you want it.
Old 09-22-2010, 07:56 AM
Frisco's Avatar
Glad To Be Here
I just did a search of his posts. You are correct. He posted pictures on 9/15/2010 of the 'C' notch he did to the rear frame rails. I'm not sure why he posted the old frame rail pictures five days later and asked the question about the springs. Probably just a slip of the finger on the keyboard when selecting the photo(s) to post.
That being said; since the frame rails have been 'C' notched, You can safely remove about half of the leaves from each spring stack. Try every other one except the main leaf. Additional leaves can be removed/added to get the travel you wish.
ID:	48257   Click image for larger version
Old 09-22-2010, 11:21 AM
IMO i wouldnt remove any leafs, i would just get new ones =/
Old 09-22-2010, 02:03 PM
adantessr's Avatar
'23 T-Bucket Pickup
Wiki Edits: 3
GM steering column tilt/wobble repair HELP (pics inside) camaroguy1969 Suspension - Brakes - Steering 18 03-05-2009 12:37 AM
Remove Heads Without Removing Intake? HotRodMan Engine 17 08-10-2006 07:18 PM
Using a Grinder to remove paint duallybuster Body - Exterior 16 07-30-2006 10:17 AM
Spindle interchanges bskaggs Suspension - Brakes - Steering 11 06-05-2006 01:29 PM
How to remove hard water stains on paint 63' Falcon Gasser Body - Exterior 4 08-31-2004 11:58 PM
