Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - How MANY PCV valves should I use?
Old 02-02-2012, 03:30 PM
poncho62's Avatar
poncho62 poncho62 is offline
Wiki Edits: 5
Do NOT use 2 PCVs, one on each valve cover......The "V" in PCV stands for ventilation.....If you have 2 PCVs with no vent, you are just going to end up sucking oil out of the engine into the carb. If you are sucking air out, you need to put the same amount of air in.
