Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - How MANY PCV valves should I use?
Old 02-02-2012, 02:38 PM
littlerocktim littlerocktim is offline
So, poncho62 is saying, "Don't use a 2nd PCV valve on the passenger's side valve cover, but rather the factory's metal elbow, which also feeds into the base of the carb., for continuous vacuuming of fumes (and possibly oil).
The passenger's side has GOT to use one, or the other. The metal elbow was installed at the factory, had a rubber hose attached, which then fed into the base of the carb.
