How many qts of fluid does a 2 speed powerglide take? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-30-2011, 02:19 AM
How many qts of tranny fluid does it take in a 2 speed power glide automatic for a routine change?
(Not counting the torque converter)
Also, what is the best gasket sealant to use on a rubber gasket and what is the best sealant to use on cork?
1969 El Camino.
Thanks.
Old 10-30-2011, 07:36 AM
evh1963's Avatar
WOLFE BOTTOM CUSTOMS
fluid
i start at 4 quarts start slowly go from rev. to low in 5 sec steps then back to park and then check with it running and warm add as needed
my shop manual says 4 1/2
Old 10-30-2011, 07:41 AM
tnsmith10's Avatar
when will it rain???
1969 El Camino.
Thanks.
never use sealant on a trans pan gasket. they seal just fine with a clean dry surface and proper torque.
2 speed powerglide chewsky Transmission - Rearend 0 05-22-2011 10:06 PM
Best non-synthetic fluid for a powerglide... ForceFed86 Transmission - Rearend 9 09-10-2009 01:14 PM
Powerglide Fluid Check Procedure dirtinla Transmission - Rearend 2 02-26-2009 09:23 AM
2 speed powerglide armysniper General Rodding Tech 2 07-14-2007 11:37 AM
68 Chevy factory powerglide-what fluid? trapperjack Transmission - Rearend 10 11-03-2006 10:30 AM
