How many times can you use arp head bolts? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-27-2011, 01:15 PM
Hello guys I am getting ready to take my engine out this weekend to put my new rhs cylinder heads on and I had this engine built two years ago and I am using the arp hex style head bolts and they where torqued in three steps to 75 ftlbs per there instructions and I had to take engine apart last December and bolted it back up again and the same bolts where used again. Question is can I use them a third time?
I know cheap bolts are the tty kind but arp are not and wondering has anyone out there used them more then twice? This is on a small block chevy first gen motor.
thanks
Eric
Old 05-27-2011, 02:05 PM
Standard head bolts can used and reused indefinitely.
Old 05-27-2011, 02:16 PM
Thats what I kind of thought but did not know for sure. I have used regular bolts over and over many times with no issues but they where not real critical bolts like head bolts. Thanks man appreciate it.
Eric
Old 05-27-2011, 04:21 PM
ericnova72's Avatar
More for Less Racer
I agree there is no need to worry, these are not like the late model torque-to-yield bolts that can only be used once.
I've reused SBC ARP head and main bolts 5+ times, if not more, and never worried about it. I'd only worry about the main studs or bolts if it broke a crank or block and thus possibly overloaded a visually unhurt bolt or stud. Then I'd trash the set.
Old 05-27-2011, 04:45 PM
Thanks guys I appreciate the info and your experience. Nothing happened wise on my engine just having some minor issues with oil on my plugs again and seemingly a internal leak of something cause have had issue at idle for a long time and I am putting a whole new top better half on my engine from heads to intake. I am going to take extra time to check every angle with a fine tooth comb to make sure it all works right and hopefully after almost two years with a dang misfire and issues with oil getting on plugs from cylinder head guides I will have the problem solved.
thanks guys have a nice memorial weekend.
Eric
How many times can you torque rod bolts? eric32 Hotrodding Basics 3 03-29-2009 06:49 PM
head bolts or head studs? head gaskets? thefloyd1973 Engine 9 07-04-2008 09:25 AM
how many times can you drop a cast iron head on the cement floor? bullheimer Hotrodding Basics 7 08-13-2007 06:41 PM
oil on head bolts and head gasket bullheimer Engine 7 05-25-2004 04:50 PM
Head bolts? jeff germano Engine 7 11-11-2002 08:11 PM
