How many volts at the coil for a ford points system - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-03-2005, 08:18 PM
junkyardjeff's Avatar
I was looking at the points in my 65 galaxie and noticed they looked kind of burnt,I put them in last summer and they only have about 3500 miles on them so I checked the volts going to the coil and I am getting 12. Does Fords have a resistance wire like GM or is resistance in the coil,I had replaced the coil last summer with one from a discount parts store for a 65 galaxie but I am wondering if using a aftermarket coil should I put in a resistor. Jeff
Old 09-04-2005, 02:26 AM
docvette's Avatar
Wiki Edits: 12
Resistor
Doc here,
Remove the Dizzy cap, use a jumper and short out the points gap.
Turn the key on and measure the coil voltage at the coil power..it SHOULD read between 6 to 9 volts..If so your OK, If not..and it reads 12 volts, you need a resistor.
The coil will show 12 volts if the points are open when you measure them because there is no opposition to the flow..(no load on the circuit, points not closed) This is why you need to jumper them shut before you test.
Your description sounds exactly like an non resistor system, points lasting about 3500 miles..and pitting...also the next thing to go will be the coil from overheat...so you want to get a resistor and install it ASAP.
If you replaced a coil awhile ago, you may have replaced the resistor with it...these sometimes mount on the side of the coil...and that's why the problem now.
Almost ALL points systems require a resistor with few exceptions such as performance aftermarket systems..
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Turbo vs Supercharger - Write up!! FastChevyTruck Engine 107 02-16-2011 12:18 PM
Wanna Talk Cars "Fords" 66Falcon Hotrodders' Lounge 17 10-01-2005 05:29 AM
Having problems with ford aod tras shift points. firewood Transmission - Rearend 10 10-07-2003 06:27 PM
'74 Ford Electical System mystical_magickal_one Electrical 0 04-24-2003 09:16 AM
Whatever happend to these guys? hot_rod_kid Hotrodders' Lounge 20 12-17-2002 09:20 AM
