How many wires connect to a sbc starter - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-29-2012, 07:36 PM
So today i was working on my elco and i came across a burnt up starter wire as i was about to replace it i came across a wire that was cut & just laying next to the other wires that go to the starter. does the wire with the arrow need to go to the starter
TOP 3 WIRES WERE CONNECT
Name:	2012-10-29 17.18.49.jpg
ID:	68699   Click image for larger version
Name:	2012-10-29 17.19.47.jpg
Old 10-30-2012, 04:08 AM
EOD Guy's Avatar
Old point/coil systems use 3, new HEI version use 2.
There is a purple wire running from the ing switch to the "S" terminal on the starter and supplies 12v to make the soleniod trip and the starter turn.
The large battery cable
A white/yellowish wire running from the "I" terminal on the starter to the coil and provides a full 12v to the coil while cranking....... it's not neded on HEI systems
There may be others wires tapping off the battery cable stud but has nothing to do with the starting system
Name:	chevy starter dia.jpg
Old 10-30-2012, 11:35 AM
ogre's Avatar
the 'Duracell Project'
you do have a 2nd big lug wire, eod guy pointed out that it has nothing to do with the starter/ignition.
it may be your fuse block feed or alternator hot wire depending on how butchered the original harness is
Old 10-30-2012, 11:40 AM
poncho62's Avatar
Wiki Edits: 5
In those years, the main accessory feed came off the starter lug.....and plenty of them rotted off.
changed from oem starter to high tork mini starter , wires .? don wills Electrical 2 09-04-2010 05:34 PM
77 Buick Wagon - starter wires?/no power roadlet_411 Electrical 3 07-23-2010 08:32 PM
Where do the wires connect? Frisco Electrical 4 08-27-2004 03:49 AM
starter wires on 82 camaro 1sweetZ Electrical 1 03-18-2003 06:42 PM
Starter wires Seon Electrical 3 09-02-2002 07:23 AM
