LinkBack | Thread Tools |
How many gears?
How "narrow" is your power band? If you want to keep things on the boil, you need to stay in the sweet spot. In some ways, the CVTs are ideal for some engines as the RPM never varies
Ask a trucker who has been saddled with an old-style Detroit that had "nobody home" below 1900 and a redline of 2300 with power falling off a cliff after 2100. You had only a couple of hundred RPM to play with, so the 15 - 23 speed boxes are needed. With all the newer 'stuff" on engines now, there may really be a need to have a near-infinite number of gears |
Staying in the sweet spot with close ratio gearing is what it is all about. Take a crotch rocket out for a spin, or just listen to one going through the gears, you can tell the rpm's don't drop much after shifts, keeping the bike accelerating quickly and through the torque band. I have a Yamaha V-Max, spin it up to about 6500 rpm and hold on, it hits redline quickly in every gear after that. I have often wanted one more gear, it's a 5 speed.
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain |
Gas prices and the need for overdrive to improve economy is what started it all. I think it is more of a marketing thing now than anything.
Artificial Intelligence is no match for Natural Stupidity Chet |
I've owned a couple cruiser bikes, a Honda 450 Rebel back in the day, and a new 1200 Sportster Low I bought in 2006. They didnt have the closest ratio transmissions, but I had a friend who allowed me to drive his Yamaha FZR 600, and it had 6 speeds as I remember, and they were fairly close, but not too bad. I drove a new 911 quite a bit in the 80's, and its transmission was a 5 speed manual, but the gears werent all that close. The gears were very long. 3rd gear was good from like 30-100mph! So you dont always need a really close ratio trans if the car makes good power at a wider RPM range, and the gearing of the rear is good too. Compare that with the SS396 Camaro I mentioned, which had the closest, shortest gears I've seen aside from an 18 wheeler! 1st was almost like a creeper gear in an old pickup! You could just switch from 1st to 3rd, skipping 2nd, and hardly even notice it...... Plus, in 4th, it wouldve been terrible at highway speeds of over 55mph. You wouldve been running at 3600 at 55mph. I dont remember, and we didnt take it out on any highways that one night anyway. As far as drag racing, look at all the guys who have powerglides who run 8,9,10 second 1/4 mile times, ending up at over 150 mph, with only 2 gears! They dont seem to have a big problem with needing all the extra gears to keep in the power band. |
I drove a Chrysler Pacifica some time ago while my Ranger was being worked on at a Ford dealer.
Had one of those 6 speed automatic trannys. The thing drove me nuts as it was always shifting. My old Chevy pickup, I could just put in 3rd and that gear was just fine from 0 to 70, and that truck is geared pretty tall (3.08). gears 1-4 are just fine and the fifth for an overdrive. |
I have a 8 speed 87 firebird (at least that is what the sticker says) 700r4 + gear vendors overdrive, gear between every gear then double overdrive (not that it would ever pull double overdrive with my gearing) LOL
My 4 cyl Ford Escape has a 6 speed auto and I hate it. it's always shifting and the computer gets confused alot of time between shifts. BUT, it does get 27 mpg so I keep my mouth shut.
I don't care how many gears it is as long as I can shift it, but the people in detroit can't seem to sell what I want.
my 54 ford truck has a 4 speed ..and 5:14 rear gears don't go on the highway..but it is still fun..
I am just now removing the extra tall gears from my Dodge as I was pushing 4000rpm just to run 65mph
Felt like I was in second gear! Bat outta hell in first but topped out around 105mph Gimmie that Chrysler eight speed an aay-dap-tor kit and some open road !! Look out ya fuzzie little creatures. |
wish they would put range selectors back in cars.. no need for more than 5 gears normal, but if the trans had a simple range selectors as a few had in the past. you could have 10 forward speeds and 2 reverse, but you wouldn't shift all of them.. As it is, I sometimes skip 4th on my truck
Good old CAFE standards mandates finding that last mpg increase a necessity. The multiple close ratio gears helps as long as the increased weight does not offset the gains. Get the gearing low enough to easily overcome the inertia may make carbon fiber type gearing possible, thus a meaningful weight reduction which will produce better fuel economy could be in the cars of the future. Electric wheel motors are going to be in the cards as soon as automotive engineers will get outside their little box and look at the locomotive industry for some new ideals. How about a diesel powered ONAN generator powering 4 tiny wheel motors. A thousand pound composite body that is as streamlined as an F-22 would become a rocket and run all day on a few gallons of diesel.
Trees |
i wish my brides 300 had the 8 speed in it . she gets 28 now but would bump up to around 32 or better with the extra gears . would like to trade for a new 300 but they dropped the lifetime drive train warranty .
| Recent Hotrodders' Lounge posts with photos |
| Change Gears or Trans? | slik | Transmission - Rearend | 26 | 10-30-2009 03:08 PM |
| Change gears or trans?? | Red neck blazer | Transmission - Rearend | 8 | 03-13-2008 10:38 PM |
| Tranny gears or rear gears? | strummin67 | Transmission - Rearend | 4 | 06-12-2006 10:17 AM |
| 727 trans no forward gears | gorf24 | Transmission - Rearend | 14 | 11-21-2004 03:22 PM |
| '67 Mustang Trans 2nd & 3rd gears going. | 67 302 | Transmission - Rearend | 0 | 02-09-2003 05:13 PM |
