How to measure backspacing - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-14-2006, 09:16 AM
Let's use this image as an example:
Lets just say that this rim is 7" wide, and has 3" of backspacing.
I want to go to a 8" rim, and I need more backspacing for my car.... so if this rim were 8" wide with 3" backspacing - there would just be an extra inch sticking out on the front compared to a 7" rim, correct? Or it will have a "deeper dish"?
Just don't want to order the wrong stuff
Thanks,
Sean
Old 06-14-2006, 09:22 AM
Backspacing is backspacing, no matter what the width of the rim. 3" of backspacing on an 8" rim would have your A dimension at 3", same as a 7" rim. If you want to move the inner edge of the rim inboard 1", get 4" of backspacing.
Old 06-14-2006, 01:09 PM
steve392's Avatar
just passin' thru
Last wiki edit: How to title a hot rod
Last journal entry: Willys is Finished!
Wiki Edits: 2
stratt,
Its like '67 says, the distance from the rim mounting surface to the inside edge of rim will still be the same regardless of overall rim width. You will just have "an extra inch sticking out on the front" and it will have a deeper dish when viewed from the outside of the rim.
Don't confuse backspace with wheel offset . Offset is the difference in distance between the centerline of the wheel and the mounting surface. For more info, go here:
http://www.rsracing.com/tech-wheel.html
hope this helps,
Steve
Old 06-17-2006, 01:16 PM
I shouldn't have to worry about offset with my application, right? I think I found the rims I need at Jegs & Summit. The specs for the rims don't mention offset on either website....
Old 06-19-2006, 07:40 AM
steve392's Avatar
just passin' thru
Wiki Edits: 2
No, you shouldn't have to worry about offset. It's just another term used for wheel dimensions. When ordering wheels, the backspace dimension is the one usually used. You should be fine.
Steve
Old 06-21-2006, 02:47 AM
lust4speed's Avatar
And a 7" rim will be 8" wide, and an 8" rim will be a total of 9" wide since both aluminum and steel wheels average almost exactly 1/2" width from the inside bead area to the outside of the rim. Therefore an 8" rim with 3" of back spacing will have 6" from the mounting flange to the outside of the wheel (9" with 3" to the inside and 6" to the outside). So it doesn't hurt to take a straight edge from the mounting area and measure out both ways to insure that there is sufficient clearance for the planned wheel.
M-II, Dropped Spindles and Backspacing? GS Guy Suspension - Brakes - Steering 1 03-26-2005 06:46 PM
Wheels and backspacing Loup Suspension - Brakes - Steering 1 04-03-2004 03:30 AM
Corvette Ralley wheel backspacing edubois General Rodding Tech 3 03-14-2003 08:59 PM
measuring for backspacing christopher406 Suspension - Brakes - Steering 3 02-19-2003 10:54 PM
Wheel Backspacing Bill Ford Suspension - Brakes - Steering 2 11-09-2002 02:27 PM
