Pipe is for conveyance (flowing liquids, gases, etc.), so the I.D. is important.
Tubing is for structures- O.D. and wall thickness as needed for weight capacity.
For instance, you might have a pipeline constructed with, uh... pipe that has the proper I.D. and wall thickness for what it's carrying and this pipeline is supported off the ground by a tubing structure that has the needed O.D. and wall thickness to handle the anticipated weight.
Conduit (electrical) is sized by I.D. since the inside volume determines maximum number of wires and their gauge(s) and is considered pipe.
Not true. Pipe i.d. decreases as wall thickness increases.
Tubing is also for conveyance of materials.
Think copper tubing or stainless tubing for instrumentation or steel tubing for brakelines, etc.
Tubing's O.D. is its size and again it's I.D. decreases with wall thickness.
Structural tubing is used for just that - structure.
Whether round ,rectangular, or square it's O.D.'s are its size.
conduit, EMT Is tubing and has a standard OD. heavy wall conduit has thicker wall but the OD is the same so all the fittings can interchange.
Related Threads
Hot Rod Forum
2.2M posts
175.9K members
Since 2001
