Hotrodders Bulletin Board
#1
How metering rods work in Rochester Dualjet ?
Me and my friend took apart 79 2mv dualjet on 305 chevy and were wondering what is a function of 2 springloaded metering rods. He was suggesting we should put rods lower into jets (openings on the bottom ) for better economy . I have no clue but it sounds good. Before he shortens that little spring, is he correct ?
Thanks |
#2
To do so will make it run leaner, which is not a wise thing to do, the metering rods control the amount of fuel the engine will get, the further they are in the jets the leaner it gets, and the longer they stay lower will result in a too lean cruise condition that will make the car surge. Too lean can cause overheating as well as other problems, the carb was calibrated from the factory for max efficientcy, I`d leave it that way.
Back to top |
Similar Threads for: "How metering rods work in Rochester Dualjet ?"
| Scotts Hot Rods, Work - Good or Bad? | dwyerk | Hotrodders' Lounge | 13 | 10-13-2007 11:37 PM |
| "a little over" turns into $4500 over for paint job | bullheimer | Body - Exterior | 128 | 02-06-2006 07:57 AM |
| Front clips and frame swaps --- More work, less value | Centerline | Suspension - Brakes - Steering | 23 | 05-25-2005 07:42 PM |
| new rods or old rods? | Blob | Engine | 12 | 02-03-2004 03:35 PM |
| Q-Jet Metering Rod Idea | Silver_Camaro | Engine | 6 | 09-16-2003 12:48 PM |
