Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - How to modify a stock ECM
Old 12-15-2011, 11:42 AM
TurboS10's Avatar
TurboS10 TurboS10 is offline
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
Originally Posted by Augusto
I others words, use a megasquirt or run a carb..!! right?
I have some experiencie with SDEFI systems in 4 cylinder turbocharged engines with good results so megasquirt shouldn't be that difficult, I like the low price of megasquirt, though SDEFI is not very expensive.
http://www.sdsefi.com/
have you used their products or heard about them?
Actually, if I do another project I dont know which way I would go. I might try megasquirt, but something like FAST appeals to me alot more after having done a diy project in the past. I dont have the time to deal with all the diy problems and I am usually looking for a faster solution. If I was going really simple like TBI fuel only, then I think megasquirt would be my choice. If it was a turbo setup I'd go with something else most likely.
