How to mount aluminum dash - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-31-2013, 07:50 PM
Brandon H.'s Avatar
I am building a cheap bracket S10. Most of the truck is stripped. I want an aluminum dash for it. No AC, radio, ect. all I need is Tach, oil, water, volt, and my switch panel for fans, water, ignition and ect.
I have the metal and metal brake and welder here to make the dash, but how would I go about mounting it in this 84' S10? There is no cage in the truck, just roll bar.
Any help or ideas?
Old 07-31-2013, 08:21 PM
gow589's Avatar
the Clever Turn Signal
Need more info as to what you want. This is one I am working on:
Old 07-31-2013, 08:34 PM
Brandon H.'s Avatar
That's a nice dash great work
I want it just like this. Easy to make, just want to know the best method to mount it.
JEGS Performance Products 70800 JEGS Aluminum Dash and Dash End Panels
Old 08-01-2013, 07:24 AM
DanTwoLakes's Avatar
Wiki Edits: 22
Let's put this in General rodding tech.
Dan
Old 08-01-2013, 07:28 AM
life is a temporary assignment
On a race type truck, They are sometimes put in with dzus fasteners...Here's a picture of one...Easy to do...
But you can also just make mounting brakets to hole it..
Old 08-01-2013, 11:45 AM
Brandon H.'s Avatar
I was thinking either that or button head Allen bolts.
So I should just weld brackets or tabs off the cab and mount it that way?
Old 08-01-2013, 02:33 PM
Banned
use these, makes getting to things much easier..
Fiberglass Dash mount question? off2wildblue General Rodding Tech 1 04-27-2009 12:28 PM
Super short dash mount steering column Stovebolter Suspension - Brakes - Steering 15 04-07-2008 06:55 PM
Kugel Under Dash Mount Question redsdad Suspension - Brakes - Steering 1 02-04-2007 08:31 PM
Aluminum Alternator mount... ground? blndweasel Electrical 5 03-16-2005 08:36 AM
Aluminum Dash allancl Interior 7 03-15-2004 08:07 AM
