How to move an air compressor - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 02-16-2012, 07:27 AM
deadbodyman's Avatar
Wiki Edits: 11
I have a 3' x4" dolly made from 1/4' angle iron with 6" iron casters I use my engine hoist to lift the compressor and set it on the dolly ,use vice grip clampe to clamp the legs to the dolly then move it where ever I need it..Piece of cake...with a smaller one like the lumber stores sell .a simple movers dolly should work but be sure to clamp the legs to the dolly so it wont tip over
  #17 (permalink)
Old 02-16-2012, 07:36 AM
Originally Posted by jbs10
just truned it on ran fine till 50 lb stutt off agin i removeed the line from the side and it will run fine but when i punt it back on it will not run ??
Sounds like the pressure switch was screwed up, compressure sutting down cause it thinks it is up to pressure, I'd start with that.
  #18 (permalink)
Old 03-03-2012, 02:13 AM
New Member
This thread contains nice information that helps to know that, how can we move an air compressor. Thanks!
  #19 (permalink)
Old 03-13-2012, 11:53 PM
New Member
How can we move a heavily weighted air compressor ? I have a 60 gallon air compressor and I just want to change it's place. Please give me some solution for this.
  #20 (permalink)
Old 03-15-2012, 08:44 AM
Wiki Edits: 11
Try an engine hoist
  #21 (permalink)
Old 03-22-2012, 05:11 AM
moving a compressor is easy.
i have a vertical 80 gallon quincy compressor with the motor and pump on the top. i wanted to move it to another place in my shop, about 60 feet away. i got some wood pallets and used my floor jack to raise the compressor enough to put some wood, 2x6's etc, stacked high enough to level out the compressor enough to where i could jack from the other side. walking it uphill was easy for me, but i had access to several good strong wood pallets, and lots of scrap 2x6 and 2x4 cutoff pieces of wood. just block as you go, and you can even get it high enough to load into the back of a pickup. be sure you have a couple of volunteers helping though. even slinging it with an engine hoist would have worked.
  #22 (permalink)
Old 03-22-2012, 07:35 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Moved my new compressor into place with my engine hoist..worked just fine and would do it again..even got it off the truck that way..
Sam
Martin Senour Tech Sheets? unstable Body - Exterior 42 03-12-2011 10:09 PM
larger compressor gburgess2002 Garage - Tools 13 07-19-2009 10:36 AM
New Air Compressor blsnelling Garage - Tools 58 10-18-2007 10:36 PM
shooting clear vinvango73 Body - Exterior 3 10-29-2005 12:24 AM
Anyone Looking For An Air Compressor ?????? STATUTORY GRAPE Body - Exterior 2 07-14-2003 07:24 PM
