How much abuse can my TH400 handle?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-20-2006, 07:36 PM
Half Breed's Avatar
Even my lawn mower is fast
I have a TH400 truck transmission that was just built by a local performance shop. I do not know alot about transmissions so forgive me, but they put alto red bands in it, upgraded sprag, hardened gears, transbrake, reverse manual valvebody,(all JW parts) etc, etc..... it cost me $1400 dollars and they promised it would hold 800hp. My motor is a 406 sbc that dynoed @ 578 flywheel hp, and I will be adding a 200 shot of nitrous. Providing the transmission has been assembled properly, how many passes down the track might it last before the next rebuild?
Thanks in advance
Old 01-20-2006, 09:06 PM
Bumpstick's Avatar
Hammer and a torch
Most likely will last till you need to freshen the engine or even longer...? Turbo 400`s are tough and when built right they are just plain bullet proof... The real killer of most automatics is torque and that SBC while good on HP the torque is not monster like a BBC so it should survive even longer... (in theory) But in time all things break...
Old 01-20-2006, 10:45 PM
Try to keep it as clean and cool as possible and you shouldn't have to worry about it for a long time.
Old 01-21-2006, 01:54 PM
Frmly sc*ot.
http://wheeliewild.com/
Check out what abuse the th400 can handle from this local OUTLAW PRO STREET racer using a big block, supercharger, and NOS.
Old 01-21-2006, 02:37 PM
Crosley's Avatar
Wiki Edits: 1659
There are many upgraded parts for the t-400. I 've build 400's for alcohol funny cars with a claimed 2500 hp.
If you are running the hp you post and 200hp NOS... you will need a strong converter with anti-balloon plates.
good luck
th350 - th400 tranny swap gilby246 Transmission - Rearend 2 03-23-2005 05:08 PM
Rebuilding a TH400 switch pitch Wmarden Transmission - Rearend 2 09-15-2004 11:54 PM
TH400 Trans bfrett123 Transmission - Rearend 1 09-10-2004 06:16 PM
TH400 power handling and RPM range Philly Single Transmission - Rearend 3 09-28-2003 04:51 PM
TH400 in firebird v/s TH400 in bonniville help speedfrk3 Transmission - Rearend 11 11-04-2002 11:19 AM
