Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - How much atf should my ford c6 take
Old 11-02-2012, 05:00 PM
mustang 671's Avatar
mustang 671 mustang 671 is offline
Hi all . I am now running in my trans with the wheels off and axle jacked up as its never had any use since the rebuild. I have a oil cooler to the front of the car ( radiator type ) i currently have around 6 litres in it and have had it running through the gears but i have been told to check the level whilst its running ? Ie opposite to how you check the engine oil .
What do they normally hold ? Its a c6 with reverse shift pattern. B +m high stall torque converter @2800 rpm
cheers guys
