Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - How much atf should my ford c6 take
Old 11-11-2012, 03:27 PM
mustang 671's Avatar
mustang 671 mustang 671 is offline
ok will try that . do you reckon even though i am seeing the max level once i start adding more it will feed its way around . also does the c6 feed out and then return through the trans cooler itself ?
cheers
