How Much Bump Travel Does Rear Need? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-12-2006, 09:57 AM
I can use 12 inch springs on my rear coil-over. To select a spring rate, how much bump travel should I allow after the car is fully loaded with four passengers, fuel, and a couple hundred pounds in trunk?
And, how much can a linear 12 inch spring compress before binding occurs?
John
Old 07-12-2006, 12:00 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
I'd say 3 inches at the solid rear axle bump stops.
Old 07-12-2006, 12:19 PM
I'm guessing but I think 3" is not enough, particularly on Michigan roads! For the occasional sharp bump, 3" seems to be enough, but when the road becomes a washboard surface with highs and lows at the pavement joints, the car will go into a rise/fall motion that when fully loaded might bottom out at 3" of travel. I think if you can get an extra inch it would be a good thing. Don't forget to check your shock to match the travel distance of the spring.
Old 07-12-2006, 04:30 PM
Whoaa!
If 3 inches or more is needed after fully loaded, I am in trouble and I don't see how most street rods handle life on the road.
Twelve inch springs can only compress about 5.5 inches total, right. So to maintain 3 inches of travel after fully loading the car (probably 1600 lbs on rear springs), the spring rate would have to be about 300 lb/in -- extremely stiff I think.
Most street rods I see on the road appear to have 10-12 inch rear springs -- do they just not load the cars down in order to still run reasonable comfortable springs?
Lightly loaded, weight on my rear springs with two people in the car (it is a 4 door car though) and a half tank of gas is about 1200 lbs. So even using fairly stiff 200 lb springs would result in a compression of 3 inches with remaining bump travel of only 2.5 inches.
Am I missing something, or is that the penalty I pay for using coil overs on a street passenger car?
John
Old 07-14-2006, 05:54 AM
staleg's Avatar
Last journal entry: Hand brake
Remember that the coilovers rarely stand straight upward.
If it leans 25 degrees a 5" travel on the coilover means 6.09" travel on the axle (divide with 0,82)
Old 07-14-2006, 11:17 AM
xntrik's Avatar
I started this 3" thing.
As I stated:
Factory leaf spring cars when loaded have about 3 inches of axle travel remaining to the frame bump stop. Load one and look at it. That probably gives you 4" of tire travel with bump under one tire only.
That is LOADED, as he asked.
How many cars need more than 3-4 inches of suspension travel when running loaded on reasonable roads. That is a lot of axle movement. Look at the fender lip/tire relationship..... do you need more than another 3 inches when LOADED? If you do, you might consider air ride.
Also consider that if you hit a 1" bump that half that instant rise is compensated for by the tire compression. If you hit an instantaneous 3" vertical rise, you hit a mountain and you probably just ruined a tire.
As far as travel and the bump stops are concerned, ask yourselves this..... Am I building a baja buggy or a street rod?
Old 07-14-2006, 01:52 PM
Go here to find the actual block height of the springs.
http://eibach.com/cgi-bin/htmlos.exe...61812100002608
One other point is that using good polyurethane foam bump stops is a very good idea to keep the car off the ground and still provide a good ride. If you look most new factory bump stops are made out of this material rather than the hard rubber of old. The poly foam bump stops are very soft. Because of that you can have the car ride on those bump stops when fully loaded (as long as that isn't too often).
As for pot holes - they require droop travel; not bump travel.
8.8 Ford rear end in my 79 G body Malibu 79 Malibu327 Transmission - Rearend 4 05-20-2007 03:26 PM
63 biscayne rear differential problems biscuit63 Transmission - Rearend 8 07-29-2005 05:37 PM
Universal 3-link kit pigman Suspension - Brakes - Steering 32 07-13-2005 04:43 PM
Best ways to straighten a twisted repro door? Ripped Body - Exterior 13 07-04-2005 08:29 AM
Rear end swap problems datsun dale Transmission - Rearend 1 12-17-2002 11:50 PM
