Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - How much can Pontiac pressed in studs take?
Old 04-30-2013, 03:23 PM
techinspector1's Avatar
techinspector1 techinspector1 is online now
Wiki Edits: 326
Originally Posted by Nuck Chorris View Post
I want this Lunati Cam for my P350: Duration @ .050 (Int/Exh): 213/219
(Int/Exh): .455/.468 LSA/ICL: 112/108 RPM Range: 1000-5300. The whole Kit and Kaboodle has valve springs in it with seat pressure 120 and open pressure at 330. I read on Crane's website that open seat pressure over 280 was too much for press in Studs. Lunati guy said press in Studs in my 68 Le Mans 350 heads should be fine. Will 320 open pressure be too much? Or can I run the same cam with a weaker spring?
I've read different values from different sources, but would agree with the 280 lbs max.
I know this is old school stuff, but that doesn't mean it doesn't work.
http://www.summitracing.com/parts/mrg-806g
The Following User Says Thank You to techinspector1 For This Useful Post:
Nuck Chorris (05-01-2013)
