Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - How much can Pontiac pressed in studs take?
Old 05-02-2013, 02:59 PM
Nuck Chorris Nuck Chorris is offline
Let me get a few something straight.
If the cam has a base circle of 1.330 then I can run it the stock set up.
The lift of the cam on the exhaust side is .468, which is a half a hair under .470.
Seat pressure is 120 which is just under 125.
It seems that so long as the base circle is good I might get away with running this cam.
Do I have this right?
