Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - How much can technique do
Old 06-15-2008, 08:34 AM
baddbob baddbob is offline
You'll need to clear that basecoat, basecoat has no UV protection and also is not very durable, a satin clear like suggested would do the trick. That JGA502 can get all of your painting done but you'll need some higher air pressures with todays high solids clears and this will make for a lot of overspray.
