Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - How much clearance should there be between motor mount and motor mount bolt?
Old 03-20-2013, 08:04 PM
496CHEVY3100's Avatar
496CHEVY3100 496CHEVY3100 is offline
Built Not Bought
Last journal entry: 53 ad3100
I dont think you have any thing to worr about ,it has to have some clearance .dont use washers or bigger diameter bolts ,the ones you have are much stronger than the rubber bonded to your mount ,just a note i had to change my frame mounts also ,but mine is an 88 it is not a bolt in like everyon said when i started . Good Luck
