Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - How much clearance should there be between motor mount and motor mount bolt?
Old 06-08-2006, 08:19 PM
dgcantrellsr dgcantrellsr is offline
Originally Posted by firstgear
I have what I consider quite a bit of clearance between the motor mount and the motor mount bolt, is this typical?
seems to me that at most there should be a few thousandths, but it is more like 1/4" to 3/8"......thoughts, nothing to worry about? I can just see the motor reving up against those bolts and getting a good chance to run up at it....comments??????
You will never know it , if it were in the thousands , you would never get the engine lined up on both sides.
