How much clearance should there be between motor mount and motor mount bolt?
I have what I consider quite a bit of clearance between the motor mount and the motor mount bolt, is this typical?
http://images15.fotki.com/v260/photo...54small-vi.jpg seems to me that at most there should be a few thousandths, but it is more like 1/4" to 3/8"......thoughts, nothing to worry about? I can just see the motor reving up against those bolts and getting a good chance to run up at it....comments?????? |
bolts
Use thick, large washers.
I dont think you have any thing to worr about ,it has to have some clearance .dont use washers or bigger diameter bolts ,the ones you have are much stronger than the rubber bonded to your mount ,just a note i had to change my frame mounts also ,but mine is an 88 it is not a bolt in like everyon said when i started . Good Luck
Is there gap in between the mount and the tang on the engine. Can the engine wiggle back and forth or is it tight fit. I would use washers to tighten the space between the mount and the tube on the engine side of the mount. This should allow you to tighten the bolts down so it doesnt move.
If your looking for smooth ride get stock mounts. Other wise tighten it down so its locked in place. It should lift a fender when it revs not just wobble around inside the engine compartment like a stock engine. |
I have to go with the point on fitting the engine. Try putting those bolts thru the mounts when dropping a motor into a 70 Camaro or something like that with the front sheetmetal on and you are laying under the car with it on jack stands. You would be damn happy to have that little wriggle room and it would be perfectly clear why it HAD to be there. If it was a few thousands you would NEVER get that bolt in! There has to be a little room to make up for flaws in the location of the mounts on the frame and motor. There is no way there can be absolute perfection in where those mounts are mounted on every frame in every car, even from the factory. A little sagging of a frame over it's life, different brand mounts, etc, there are way too many variables to ever have a perfect hole for that bolt to go thru.
Use the larger, thicker washers and tighten it up well and there you go.:thumbup: Brian |
Bogie |
Use grade 8 bolts with flat washers and locknuts. The bolts should be 4 1/4 x 7/16.
| All times are GMT -6. The time now is 05:34 PM. |
