how much coil to cut on a 65 Chevy truck - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-02-2013, 07:20 PM
How much coil spring can I cut off my 65 chevy truck? I want it to be as low as I can get it without it being so rough of a ride that I can't drive it.it has a 04 350 vortec in it.id like it to have a little rake to it and dont want the tires to rub over bumps or while turning.
Here is how id "LIKE" to get it.
And here is a pic of how it sits now. I can get more details if you need them.
I know cutting the coils isnt the best thing to do but im trying to get it ready for the Rodrun in pigeon forge in September .
I just need a general idea of how much to cut front and back.
Old 08-02-2013, 08:38 PM
lakeroadster's Avatar
Hot Rods are Built, not Bought
Last journal entry: Lakeroadster's '31 Model A Tudor
Originally Posted by LONGBOX55
Cutting the coils will not get you what you want, best bet would be to get the proper drop springs and do it right the first time. Cutting the springs will alter the rate, both from coil removal and by changing the temper of the springs from the heat of cutting them. You'll end up with the rough ride that you don't want. In addition, it's difficult to get an exact dimension to cut to get a given amount of drop. You have to consider the spring wear, plus the temper change.
Summit shows drop springs for your truck. Most of them look like they are in stock and ready to be shipped, should be able to have them within a week at the most.
Old 08-02-2013, 10:50 PM
Banned
get some j/y jeep wrangler rear springs and stuff them under it..(rear) this give about 3-4"
fronts buy the coils, they are short money.. get 3" for the front.. and see if you like it
cutting the coils will make it ride like a dumb truck.. ruff ride.
rears you can't cut as they pig tail at both ends(at least my 71 does)
the fronts, try a 1/2 coil and when close 1/4. plan on ripping the front end apart a few times to get it right..
and why I'd pony up for the drop springs in the front..
which coil to cut cornfieldcars Suspension - Brakes - Steering 12 06-23-2011 10:35 PM
350 engine just cut out on my truck TASHAN Engine 10 05-26-2009 05:27 PM
If you do need to cut your coil springs BinderRod1939 Suspension - Brakes - Steering 8 08-09-2004 08:37 PM
If I cut a coil spring Bluepen Suspension - Brakes - Steering 2 06-01-2004 06:06 AM
Cut Coil Springs ? zachscc Suspension - Brakes - Steering 18 01-10-2003 07:10 PM
