how much comp. should I reach for on 350? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-02-2008, 06:23 PM
Alright guys this will hopefully be the last post on this project, Gen 1, 2 bolt 350, Flat top piston 2 valve relief, not sure what cam yet with cast crank, and stock rods. question is what is the MOST compression i could run and still use 92 pump gas, or be right on border line. and what heads would get me there, 58cc,64cc,65cc,75cc etc.... or a list of what the compression would be would be great,... thanks guys
Old 11-02-2008, 06:29 PM
04SilveradoMykk's Avatar
What pistons did you use?
I've got Speed Pro (Federal Mogul) H345NCP-40 flatop four valve relief, .004" from deck. .039" compressed headgaskets & Vortec 64cc heads.
If I remember correctly the estimated compression on mine is 10.2-1,and I've been using 91 octane without a problem
Old 11-02-2008, 07:54 PM
Banned
I've heard of 12 and even 13:1, but that was in a super expensive build with all of the tricks. For general hotrodding most stick with 11:1 or less- and even then you better have that thing built and tuned perfectly. since it appears you are not well versed in engine theory and dynamics I would recomend 10:1 or less.
Keep in mind for streetable power 10:1 can be a LOT better than 12:1.
Old 11-03-2008, 01:21 AM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
That question is like asking "how hot a girl can I land tonight?" It depends on a few thousand factors including driving style, auto or manual, iron or aluminum, domes or flat tops, cam timing, thermostat temp, accuracy of the fuel tune, effectiveness of the ignition system, turbulence in the chamber, squish and quench... the list is nearly endless.
Master tuners using all the expensive mods can get a 12:1 engine to run on 87 octane, while a ham-fisted novice might not be able to get an 8.5:1 engine to run on 93.
Cam/Lifter Question about Ramjet 350 Jake Harsha Engine 20 07-07-2010 06:22 AM
Bog/Black Smoke on Olds 350 at 3000 rpm JohnTN Engine 4 03-17-2009 11:39 AM
Why not a 350 sbc? bowtieorbust Engine 29 09-05-2008 09:43 AM
possible 350 block purchase - comments please idrva55 Engine 17 12-09-2007 09:29 PM
327or 350 70 nova Engine 5 07-27-2003 10:14 PM
