How much to cover a frame? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-08-2005, 05:02 PM
Malibucdl's Avatar
Laissez les bons temps rouler
Last journal entry: Frame Removal
I hopefully will be painting my Packard frame sometime soon. But I am trying to figure out how much paint I will need. I plan on using Por-15 ChassisCoat Black after sanding and blasting the frame. How much do you think it will take to do the complete frame and suspension? It is sold by the pint, quart, and gallon. I am thinking 2 quarts, maybe?
Chris
Old 08-08-2005, 05:27 PM
Wiki Edits: 49
A buddy of mine just bought POR for his 41 Ford frame. The POR guy at the Nats booth told him about 2 quarts will do the whole thing plus all the suspension.
Old 08-08-2005, 07:57 PM
Eric Von Zipper's Avatar
Ole Skool Greaser
Chris
Two coats, the POR-15 then the finsh coat of chassis black. A two step procedure. 2 quarts of each will be plenty.
Trick: dont open the can by the lid. drill a hole about 1/4 way down, pour out what you need, then screw a sheet metal screw in the hole. When you need more, drill another hole further down. Keep the can air tight and you wont losse as much to hardening.
Oh yeah use cheap brushes and throw them away, you aint gonna clean them after POR 15 been on them.
Old 08-09-2005, 01:10 AM
Malibucdl's Avatar
So your saying I should put 2 coats of POR-15 Rust Preventive Paint, then 2 coats of the POR-15 ChassisCoat Black? I was rading the POR-15 site, and from what I understand, the ChassisCoat can be applied to raw metal. Is this not a good idea? Should the Rust Preventive be put on first then the ChassisCoat?
Chris
59 Chevy pickup frame woes! Li'l Pine Suspension - Brakes - Steering 33 07-08-2009 09:24 PM
Cantilever system for air bags 53LEDSLED Suspension - Brakes - Steering 17 12-05-2004 04:26 PM
frame for a 38 chevy. what should i use to cover it violent j Body - Exterior 18 07-17-2004 11:37 PM
Body & Frame question ruiner808 General Rodding Tech 7 09-14-2003 06:54 AM
Best Bedliner ... Frame Rails ... Toneau Cover? horvath Body - Exterior 5 04-20-2003 07:50 AM
