i decided to chop my 48 chevy pickup 5 inches how do i measure the front windsheild post to cut the 5 inches out of the post, on the back of the cab i measured 7 inches up from the top of the body line below the back window this will be the bottom cut. but i have been told on the front winsheild post i can not measure along the angle of the post beacause it will not actually give me 5 inches. what tools will i need and how should i go about this.
When I chop, I set the body as level as possible and measure from the floor. Remember when you come down with the top, it will also lengthen due to the angle of the windshield. It helps if you can draw a profile life size and kind of measure from that reference posted on the garage wall. That's what I did for my angle chop. There may be a way to mark off reference lines in tape on the door also...? Just suggestions- good luck!!
Before you jump into this headfirst I would suggest doing a search online and finding some reference material. There are a ton of books and online sites that will give you the basic idea, the tools to use and how to get started. I think you need to get some background in welding and finish body work if you want this to turn out well and not look like a botch job.
Mark
ya..I was gonna have to replace the rear 1/4's anyway, plus I had to move the body from my parent's garage, to a garage 30 minutes from where I live..the trailer I had was too narrow for the fat impala, so I had to narrow it down a bit
one of those incidents where hind sight cleared up after the beer went away....plus I was in a hurry cause my parents were pissed about the body being left in their garage for a long time
Related Threads
Hot Rod Forum
2.2M posts
175.7K members
Since 2001
