how much does the cab weigh - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-06-2011, 08:05 AM
how much does the cab of a 57 3100 weigh
Old 12-06-2011, 11:30 AM
I don't know how you can figure this out without doing it, and I don't see why anyone would so your answer is going to be a long time coming. Why do you need to know this?
My guess, 300 lbs without the doors, seat or glass.
Old 12-06-2011, 01:06 PM
want to lift cab off frame using the beam in my garage just want to make sure I dont pull the house down
Old 12-06-2011, 01:14 PM
Ahhhh, LOL. yeah we don't want to pull the house down. Listen, how big is that joist you want to use? If it's a 2x10 and is properly supported at both ends I would think it's plenty. Of course you could put a 4x4 over the top across a couple of joists and then you would have no problem at all.
That, or get a three friends and lift it off. Are the doors off? If it's empty it isn't a big deal with a few friends.
Old 12-06-2011, 01:15 PM
Working by myself in a one man shop for years I found ways to do that sort of thing by myself. If you lower the frame to the ground you may be able to move it a little at a time to the end of the frame then off onto a cart or something.
Old 12-06-2011, 06:56 PM
It's steel I beam but it holds up the entire house above me. I'm sure it's strong enough just want to be certain. So four guys should have no problems carrying it away?
Old 12-06-2011, 08:41 PM
Is is stripped of doors and such? That makes a HUGE difference. I have pulled them off with four guys no problem but if the doors and such are all that will make a big difference, I don't know in that case.
Old 12-07-2011, 10:44 AM
ogre's Avatar
the 'Duracell Project'
2 guys can lift it, but use 4 as you have to walk it around the wheels. i had 3 guys at the shop pick my 58 cab off the truck and onto a dolly a couple of times. like martinsr says; no doors, no glass, gut the cab to make it lighter.
if your doing a mustII leave the cab on until you get the x-member in, the motor/trans hung and your steering fabbed up. one less time to replace the cab.
Old 12-07-2011, 10:45 AM
ogre's Avatar
and check out 55 to 59 chevy truck owners we hang out there.
how much will it weigh me down? Formula_Dave7 Suspension - Brakes - Steering 3 11-19-2007 02:56 PM
How much do I weigh?? mustangman46 Hotrodding Basics 4 07-24-2007 07:48 PM
how much does it weigh? Nova Boy General Rodding Tech 8 04-16-2006 08:01 PM
how much does my car weigh? CJ2AWILLY General Rodding Tech 0 06-03-2003 07:45 AM
How to weigh your car taffy General Rodding Tech 7 03-17-2003 07:21 PM
