How much does th 350 weight???? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-02-2004, 03:38 PM
61ChevyTruck's Avatar
Yeah, I did set-off your alarm
i'm gonna be putting in a rebuilt 350 in my truck how much does it weigh dry????? i need to know if i'm really gonna need a tranny jack or not!!!!
Old 09-02-2004, 04:22 PM
bullheimer's Avatar
NEVER use credit cards!
it wieghs more than you can lift. get a jack. rent one
Old 09-02-2004, 04:24 PM
Camarofiend73's Avatar
575 lbs.
http://www.team.net/sol/tech/engine.html
Old 09-02-2004, 04:33 PM
Ghetto Jet's Avatar
pic of my Cobra should be here
Last journal entry: Lets Get Started With the Improvements
Originally posted by Camarofiend73
575 lbs.
This would sound stupid, but since you posted the weight of a 350 scb, Are you talking about a 350 motor or a th350 transmission?
Old 09-02-2004, 04:48 PM
i'm talken about a TH-350 transmission i thought they only weight like 140-200 pounds!!!!!
Old 09-02-2004, 05:23 PM
OOps! My bad- didn't see the "TH"-
Dry weight about 130lbs.
Old 09-02-2004, 05:30 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
Around 150 pounds empty.
The different output shaft lengths will make a small difference, 4, 6, 9 inch, and the 4WD model will weigh the least with 5/8-inch with NO output shaft, output shaft housing, or speedo gears.
Old 09-02-2004, 05:39 PM
adtkart@aol.com
You can lift and carry them standing up if you are in decent shape. Lifting one and holding it in position to install with the convertor is going to be a stretch. It is also going to be dangerous. Rent or borrow a jack, you'll be glad you did.
Old 09-02-2004, 09:22 PM
Be sure you can get the vehicle up high enough. My T350 on top of my cheapo transmission jack was ~27" high, & my jack wouldn't lift the truck high enough to roll the whole mess up under it. I had to put the trans on the jack AFTER it was all up under the truck, & oh what fun that was. I now have a bigger jack & taller jack stands.
Old 09-02-2004, 11:02 PM
Old School Nut's Avatar
machinest & A&P Mechanic
Last journal entry: distributer housing...
yeah get a jack, its well worth it, its possible to get them in without them i have done it myself using blocks in the winter time outside! but let me tell you it was NOT fun... i had a jack for the next tranny i took out and put in.... i had a friend that was built like a body builder, ya know, no neck, huge arms, he installed a th350 in his truck with no jack, he was strong enough to hold the sucker in place, keep the torque converter in and get a bolt started... he did admit tho that it was almost to much for him. so if you arnt one of them body builder types get a jack, blocks are a pain and i dont think are very safe (blocks and tranny fluid are pretty slick) (niether is holding it with one arm like a bench press under the vehicle while trying to screw in one of the upper bolts...)
Old 09-02-2004, 11:10 PM
Siggy_Freud's Avatar
Its a two or three person job without a jack (unless your abnormally strong and skillful lol). The jack would make it SOOO much easier.
Dont be harder on yourself than you need to be.
Bringing history and technology together.
Old 09-02-2004, 11:57 PM
well i'm gonna be doing it at work we have a lift and air tool yeehaw but downside i don't have a tranny jack, but i have some stands i can use and we have a middle roller so i can pop a jack on there, i'm a big guy i can lift that, but yes indeed it would be hard to hold it up and start a few bolts. if its at the right height i can have the stand on the tail of the tranny, and use my shoulder a prop it up and i can a free hand to start a bolt i think that might work.
Also how hard is it to take the torque converter out??? or do you think the new tranny will come with one i'm sure they don't so i guess i'll have to use my old one, but i've never taken one out. i wonder how much one is if i do decide to buy one how much stall should i get i have a 307 with a cam and intake and 4 barrel carb, 1500 rpm stall??? i'm not gonna be racing...... a lot!!! just at stop lights when i'm next to some ****y ricer!!!!! well thanks for the input and help guys if i have a problem i'll get online and ask away.
Old 09-03-2004, 11:41 AM
its not hard to take the torque converter out, it just slides out. however when you install it MAKE SHURE that the torque converter is all the way bottomed out in the tranny. if you install the torque converter when its not bottomed all the way in the tranny YOU WILL ruin your tranny (eats the pump out). when you install the tranny be shure that the torque converter can spin freely and not hit the flexplate. btw i would use a new torque converter.....
Old 09-03-2004, 01:50 PM
just put new tranny in my truck this week with regular floor jack had truck about a foot high on stands
if i were u i would buy new converter w/ slightly higher than stock stall
Old 09-03-2004, 04:20 PM
Ghetto Jet's Avatar
Do they weigh more or less than a dry TH200-4R, I would just like to know because I've been carrying mine around the garage thinking it weighed only about 100.
