How much fluid for 4l60e trans? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-15-2008, 09:51 AM
I installed a freshly built 4l60e transmission into my 56 chevy and am ready to fill it up. How much fluid does this transmission hold, including the TC?
Do I add the full quantity at once or in increments? Do I add it with the engine running or can the engine be off?
Thanks,
Old 12-15-2008, 11:35 AM
tnsmith10's Avatar
when will it rain???
the trans will hold anywhere from 11 1/4 qts on up. start with 4 qts, start the vehicle and then add till u get to 11 qts., then run through the gears and recheck. will take a bit more to top off.
do not start the engine without any fluid in the trans, and it must be running to fill after the initial 4 qts or the trans will not properly fill up and most likely puke out of the vent.
allways check level with engine @ operating temp, and with the trans in park. (at least the 4l60e)
also, unless uve added a deep pan, or a extra large aux. cooler, most likely it wont take over 12 1/2 qts. gl.
master cylinder interchange runn141 Suspension - Brakes - Steering 7 05-03-2009 05:15 AM
Trans fluid additive reborn55 Transmission - Rearend 12 04-21-2007 09:52 PM
Transmission fluid problems? Croz Transmission - Rearend 7 12-22-2006 01:37 AM
synthetic transmission fluid upgrade deddy37coupe Transmission - Rearend 2 06-27-2006 10:57 AM
B;owing trans fluid out the fill pipe Sandman Transmission - Rearend 5 06-05-2002 08:29 PM
