How Much Foam to put in a Fuel Cell??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-28-2006, 10:39 AM
texastomeh's Avatar
How much foam should you put in a Poly fuel cell being used strictly for a street application??
When I ask; "How much" - I mean "how full" ( 25%, 50%, 100%, etc.) starting from the bottom . I realize that the "amount" will depend on the capacity of the cell. In my particular application I want to go with a cell that is ~ 36"L x 10"W x 14"H. I realize that I will need to make provisions for clearance of the pickup and sender tubes.
I would also welcome any comments/recommendations/suggestions that anyone might have re installing the foam.
I searched the Knowledge Base and previous threads, but was not able to find specifics. If it has been addressed, feel free to just point me.
Oh, by the way, I have read most of the several threads dealing with the foam potentially breaking-down.
texastomeh
Old 11-28-2006, 11:05 AM
cboy's Avatar
Last journal entry: Finished
The foam in my roadster cell is about 1/3 of the way up. This is the way it came from the mfr. If you want to get real exact, just holler and some of us with cells can do some measuring.
Always learning...and sharing what I've learned. The Scratch-Built Hot Rod.
93 Suburban fuel pump sabino56 Engine 8 09-10-2005 02:54 PM
Carb size to small???? brainsboy Engine 50 08-14-2005 04:04 PM
fuel cell set up??? fireforsin Engine 3 08-13-2004 07:53 AM
Fuel Cell help onecoomofo Engine 6 02-06-2004 12:10 PM
FUEL CELL WHTwall51 Engine 2 02-22-2003 09:22 AM
