How much heat to slightly pull back in place the A Pillar? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-20-2006, 10:53 AM
Guys the truck I'm working on was slid on the side and on impact slightly pushed the drivers side A Piller in. I've check the whole A-Pillar and there is no kinks in the pillar but you can tell it got pushed back a little. I want to pull it back into place but was wondering how much heat I would need to apply to the A Pillar metal to get it bend back in place.
Thanks
MP
Old 02-20-2006, 11:01 AM
I wouldn't apply any heat. Just pull or push with a porta-power.
Bob
Old 02-20-2006, 11:05 AM
crashtech's Avatar
Technician
Last wiki edit: Epoxy primer
Wiki Edits: 17
I would not use heat. If you can get ahold of some pillar-to-pillar upper body measurements, that would be good. I've been able to correct pillars with a large (9/16 thread) eyebolt through a door hinge bolt hole. Usually if you bend some tangs the captured nut for the hinge bolts will come out and a large load spreading plate can be put inside the pillar. This is just generic advise though, pics might help.
Old 02-20-2006, 11:43 AM
"This is generic advice", boy is that an understatment! Crashtech, you are right on the money (as usual). Without seeing it, there is no way we can say what "to do" but we can tell what you "could do".
MP, that post "could" be in, or just an illusion because of other parts that are bent. The pillar could be in all the way from the side of the cowl, you don't know. Seldom will something like that show a "kink" because it gets bent over such a long area.
I just did a Honda that the pillar was "smashed" in the way it was damaged. It was IN about a 3/16" along the side but was not "bent" at all. It looked bent, but with some measuring I found that the pillar and door surround over the top of the door was only knocked out of shape. The inner points all measured good. So used my "Basics of Basics" dent pulling method and pulled it all back into shape and it needed very little filler to smoothout where I had cut off the pulling piece.
I am not saying this is your problem, there is NO way any of us can tell you what will work. You need to measure, measure and measure again to see what is out of whack.
Have you hung a door on it?
Old 02-20-2006, 06:03 PM
Brian_B's Avatar
Lost in the 50s!
Last journal entry: time to start body work
The others have done this more than I have, but no heat. After carefully measuring everything many times, use pressure (porta-power) to push/pull. I have straigntened a lot of things that way. Some were even cars.
body parts fitting anyoldchevy Body - Exterior 10 02-20-2005 09:20 AM
Door Alignment Ron M Body - Exterior 2 08-21-2004 01:43 AM
Removing fenders? Jag Daddy Body - Exterior 3 11-26-2003 04:42 AM
body panel alignment gmonkey Body - Exterior 5 09-01-2003 06:50 PM
