How Much Horse Power Will I Make 350 Chevy - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-01-2006, 09:27 PM
I Have My 79 350 Built And This Is What I Have Done
350 30 Over Sealed Power .125 Dome Pistons,5.7rods 882 76cc Heads With 194 In/160 Ex Valves, Voodoo Cam 489 In/ 504 Ex 227 In/233 Ex Dur @50, Summit Roller Rocker 1:6 Ratio Tunnel Ram With Dual 450 Cfm Holley, Billet Msd And A Msd6a Box For Spark. The Trans Is A 350 Turbo Built With A 2000 Stall This Is Going In My 23 T Bucket With A Ford 9 3.00:1 For Hiway Crusin Thanks Dave
Old 03-01-2006, 09:52 PM
I dont have a desk top dyno, but I would probably say somewhere around 310-320 hp at the flywheel. The heads are what is hurting your power.
Jeremy
Old 03-02-2006, 01:15 PM
firestone's Avatar
http://teamrfc.gospelcom.net
Here are a bunch of combos to compare yours to. Most of the stock heads in this set of combonations have been ported a little, so I would subtract around 15-20 hp from what you see here. I think yours should be around 330 hp.
http://www.ryanscarpage.50megs.com/combos1.html
Old 03-02-2006, 04:09 PM
Banned
You really need to do somethign about those heads. Either spend a lot of time porting them or get a cleaned up set of vortecs with larger valves.
Old 03-02-2006, 04:43 PM
heads
i dont have a heavy boat the 23 t only weighs out at 1800-1900 lbs so for the horse power its more than enough. kit
car magazine ran the 1/4 against a porsche with a mild 350
he ran 12.38 et and dusted the porsche so i am not to worried about being to strong and have you ever drivin s straight axel allot of power is not good
Old 03-02-2006, 05:32 PM
Banned
yea, but if you make your engine more efficent you can go with a shallower differential gear and actaully gain MPG in the long run. Plus pullin up the front wheels is always fun.
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 07:57 PM
finally finished chevy 350 build redneckrodder Engine 7 05-30-2011 07:03 PM
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 01:38 AM
Chevy 350 Engine & Trans in a 46 Chevy Pickup Warner Engine 4 02-11-2005 05:44 PM
327 or 350 chevy (please no rookies) chris oswalt Engine 16 12-11-2004 09:29 PM
