how much horsepower do you guess amate - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-28-2009, 11:37 AM
how much horsepower do you guess ??
468 gm(454 bored)
holley blue fuel pump
4000lbs truck
long tube headers 1 7/8
dual exhast /cross over
stock flat top pistons 9.5.1 comp
mech cam 255/263 lift .555/.551
hurrican single plane intake manifold
patorait heads alum -1.88 2.19 320 cc
flat tappet
new rockers/rods/etc
super street carb 830cfm
posi 373 rear
alum rad /trans cooler/oil cooler/elect fan/
power glide trans
any guesses out there really appricate
Old 08-28-2009, 11:55 AM
ericnova72's Avatar
More for Less Racer
Really need to know more specifics on the cam #'s and cylinder head flow #'s. I can tell you one thing, unless you had the Patriot heads heavily milled and the block zero decked, there is no way you are anywhere close to 9.5-1 compression with a flat top piston. More like 8.25-1. Do you know the actual chamber volume of the heads??
Carb is small for an engine of this size with those heads.
Give us some more info.
Old 08-28-2009, 01:11 PM
the heads where milled .5000
cam 2500-6400
110 but degreed to 108 /dur 255-263 lift .555 .551
stall 3580
manifold 2000-7500
i know the guy i buy it from
started from the block up rebuld i know him pretty well he said
it had 9.1 comp
not sure on the flow on the heads i just know 2.19 -1.88/ 320cc
my mistake 830cfm super street /double pumper
street / strip truck
Old 08-28-2009, 05:08 PM
anybody else?
Old 08-28-2009, 07:03 PM
techinspector1's Avatar
Wiki Edits: 326
Please post the "90% of the time" usage of the truck, along with the cylinder head chamber volume, cam mfg and part number. Looks like a mis-match to me, particularly with the single plane intake if this is a street truck. Depending on chamber volume, waaayyyyy too much cam or waaaayyyy too little static compression ratio, depending on how you look at it. Bottom end will be waaaayyyy soggy. Post up all the details and let us help you.
Old 09-03-2009, 09:13 AM
DoubleVision's Avatar
Since it weights 4000 pounds the PG is not going to help matters any, especially with 3.73 gears. Most of the time when PG`s are used the stall converter is around 4000 and the rear gear is 4.56 or lower. a TH400 would work far better than the PG would in a vehicle that heavy.
Old 09-03-2009, 10:38 AM
American Muscle's Avatar
305 Turbo-Fire 240hp
Come on down your the next contestant on "Guess that Horsepower"
Guess my peak power and win.... curtis73 Engine 18 10-19-2006 10:36 AM
Horsepower.... and horsepower loss PonchoTA79400 Engine 3 03-13-2004 10:25 AM
free horsepower! minesblown Engine 3 10-05-2003 11:50 PM
302 VS 347 Really a horsepower difference?????? lakecityg Engine 12 07-13-2003 09:20 PM
Horsepower on the Target Master 350 chevylovingfarmboy Engine 1 03-06-2003 02:31 PM
