Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - How much horsepower you think she'll make.
Old 05-17-2007, 02:11 PM
americanLT1 americanLT1 is offline
Last journal entry: Body work
Still a long way from finished but, wanted to share my project with you guys and though it would be interesting to quiz you guys and get some estimates of horsepower and torque numbers I might expect with this combination. This is my first turbo motor so I'm not sure what to expect and I'm certain I'll have a learning curve. Its a LT1 350, the motors not built yet because I 'm still using it for mock up. The turbos are Garrett GT32's with 71mm compressors and a T3 .78ar turbines and, I'll be using AFR 190 heads with about a 8 to 1 compression ratio. The cam motion camshaft is 220 218 @ .050 lift and .553 .531 lift on 114 lca. It is inter cooled and will have water/alcohol injection.
My initial goal was only 600rwhp but who knows, only the dyno will know for sure. Anyway, It's fun to share and get input, good or bad.
Here's a couple of pictures of the motor and what it's going in.
Be Cool. Ed
ID:	21260   Click image for larger version
ID:	21261   Click image for larger version
