Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - How much horsepower you think she'll make.
Old 05-18-2007, 02:12 PM
53_belair 53_belair is offline
I think that the T3 turbines will be a good match for this as it sounds like it will see the street often. I dont think that they will be all that much of a restriction at "higher" rpms, the import crowd uses them on allot of high strung motors with good outcome. Being that you have the smaller t3, spool up should be good, your compression sounds about right as well for the boost you plan to run. I see this making your goal at the wheels on pump gas easy. What are you going to be running for management?
