How much HP, 4 valve - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-10-2011, 03:53 AM
klx650sm2002's Avatar
I was hoping one of you guys would do the desk top dyno thing for my 650 single, specs are as follows.
bore 100mm, 3.94"
stroke 83mm, 3.27"
intake valves 2x37mm, same as 1x2.06"
intake lift 8.8mm, same as 0.490"
exhaust valves 2x32mm, same as 1x1.78"
exhaust lift 8.3mm, same as 0.462"
inlet cam open 17 btdc, close 63 abdc.
exhaust cam open 53 bbdc, close 27 atdc.
CR 9.5
exhaust pipe, 1.75" od, 16g.
Thanks in advance,
Clive W
p.s. anything else needed just ask.
Old 12-10-2011, 12:44 PM
techinspector1's Avatar
Wiki Edits: 326
You may get more info from a KLX-type forum....
http://www.planetklx.org/
Old 12-11-2011, 10:33 AM
I have been all over the internet and not found much at all, quite a lot of 250/300 stuff not much for the 650, thats one reason I came here, similar cylinder capacity.
Clive W
broken valve? valve spring is sitting off center from rocker tip. zoomo Engine 63 03-25-2011 08:37 PM
how do i measure valve seat for valve head diameter? 406 ss monte Engine 2 04-07-2010 09:36 AM
isolator valve, sleeve, regulator valve for 4l60e? mike 96 ws6 Transmission - Rearend 28 01-29-2006 11:16 AM
Is this (bigger) valve sitting right afte the new seats and valve job? sizemoremk Engine 16 12-11-2005 12:18 AM
Can the dual coil valve springs on a BB destroy Valve guide seals Auto-Part Engine 4 11-25-2003 05:23 PM
