How much hp am I lossing? performer eps vs performer rpm - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-09-2013, 09:13 PM
i've got a .60 over 350 chevy with 10:1 compression, ported 601 heads with 2.02 1.6 valves, short tube "block hugger" headers, a xe274h comp cam .490 lift
and a 600cfm 1405 edelbrock performer carb with a 1 inch open spacer
now for the question, how much hp am I killing by running a performer eps manifold as opposed to the performer rpm ?
I have both intakes, i run the performer eps because it's endurashined and it looks ******, while the rpm is just natural aluminum
I don't race my car, but if i'm really killing power big time with the eps i'll switch it out
Old 02-09-2013, 09:29 PM
vinniekq2's Avatar
not much,five or so,horses
Old 02-10-2013, 03:24 PM
Bump to the top
Looking if anyone else has anymore feedback
Old 02-10-2013, 03:50 PM
vinniekq2's Avatar
get a bigger carb.the 600 is holding you byack more
Old 02-11-2013, 04:55 AM
I hate edelbrock carbs. Get a holley 750, 3310 and use the RPM intake if you have the hood clearance. 70's Covettes have this issue, as the RPM intake doesn't fit under the stock hood so are limited to the performer or torker intakes.
I say you are losing at least 15 hp. The performer losses power compared to the RPM on cams over 255 to 260 degrees (advertised duration) and gets worst as the cam gets bigger.
do a web search. I found this article right away.
Dyno-Testing Small-Block Intakes - Induction Extravaganza - Mopar Muscle Magazine
Old 02-11-2013, 08:51 AM
Moedog07's Avatar
Not much 5-10hp
Old 02-11-2013, 09:18 AM
A bigger carb is definitely in the horizon, just wondering if the intake in itself was causing a huge loss of power
I added the one inch open spacer as a band-aid to hopefully get some little power in the top-end
Any who, thanks guys, I guess a test would really have to be in order
Edelbrock Performer vs Performer RPM vs Air Gap RPM Regal Beagle Engine 10 02-16-2009 07:07 PM
Performer eps manifold.... DarknessSpawned Engine 3 04-01-2008 05:45 PM
289 intake performer or rpm performer pi71 Engine 4 07-10-2007 11:56 AM
anyone compare a new EPS intake to a Performer? bullheimer Engine 5 02-20-2006 05:55 PM
Performer vs. performer rpm Q-jet 85CHEVY Engine 3 08-18-2005 09:45 PM
