how much hp could 882's heads make - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-11-2007, 05:45 PM
how much is max hp that a set of casting# 333882 heads can make with doing the valve job and all the machine shop work done to it
Old 12-11-2007, 07:48 PM
DoubleVision's Avatar
The better question is how much are you looking to make?
Old 12-11-2007, 08:45 PM
Jmark's Avatar
Jokes310 seems to be in a mood tonight, making goofy posts that are being deleted as we speak. Maybe need to let the meds kick in before getting too involved in answering too many more questions.
Speaking of meds....how's it going DV!
Mark
Old 12-11-2007, 09:18 PM
Is There Anybody Out There?
Too much
Those 882's, I've had motors that had them on 'em. One, in particular was a 400. I bought it from my brother, whole car, '72, std bore. I plucked it,shoved some FT, a 290 adv/218*@.050/.450" 114 GK cam and I ran it in a '79 Rallye Sport for 10,000 miles with a two barrel before ever thinking of needing a 4! They worked very good on that motor and it would shred the tires every single day.
I recently gave a set of 882's away, brand new fresh, with roller tip rockers. I couldn't think of anything I'd use 'em on, nor was I going to.
Old 12-11-2007, 11:41 PM
Mark
what did you mean by Speaking of meds....how's it going DV!
Old 12-12-2007, 07:22 AM
with 10.5:1 cr, a compcam 292H, proper valve springs, headers, performer rpm intake, and a holley 750, those heads could make 380 to 400hp. But you would also need 4.11 gears and a 3000 rpm stall converter.
That same engine with a set of dart 200cc iron eagles or a set of 195 afr's would make 450hp.
Old 12-12-2007, 02:35 PM
Jmark's Avatar
You were making some goofy posts last night that us moderators were busy deleting.
The "meds" part was a joke and also directed at DV (doublevision)
Old 12-12-2007, 02:41 PM
He Means me, I`m DV. Mark and I have a long going joke about meds as sometimes we get guys on here that drive us crazy enough to want to take prozac. Also for a while I was on many meds as I was recovering as I still am from back surgery. The only meds I take now is advil. As for the line "Is there anybody out there?" Comes from Pink Floyd`s 1979 CD The Wall and it has nothing to do with meds or drugs, I`ve never did a Illegal drug in my life and I`m proud of that fact. I`ve had that line on there a while now, and it means just what it says, the meaning it has for me is what many don`t realize, You are all you got, you is all your ever gonna have, so in reality, your alone.
Old 12-12-2007, 04:16 PM
Have you noticed that Prozac does the same thing to your life that Muzak does to people in an elevator?
Bogie
Old 12-12-2007, 05:10 PM
Jmark's Avatar
Bogie
ROFLMAO!!!! Good one!
Old 12-12-2007, 10:17 PM
Maybe if I`d ever taken Prozac I would have.
Old 12-13-2007, 01:16 AM
biggest valves on a 882
what are the biggest size valves that you can put on some 333882 heads
Old 12-13-2007, 09:57 AM
valves size on a 882
what are some good cast iron heads for performence can you guys send me some casting #'s because with all of these bad experiences from people made me change my mind about these heads. thanks
Old 12-13-2007, 10:07 AM
What is your application??
compression ratio, cam, gear, transmission, cid, street/strip??
Old 12-13-2007, 10:32 AM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
That advice has been given to you once already. You should go back and read the replies to your initial post in this thread, especially posts #3 and #7.
tip of the day #13.999 ahh heck, lets just make it 14 kenseth17 Body - Exterior 1 09-30-2005 01:24 PM
olds 403? Meka Engine 15 09-11-2005 01:48 PM
sbc heads shieldbreaker Engine 5 08-27-2005 08:12 PM
about how much hp and torque will I make? sb72elcamino350 Hotrodding Basics 8 06-21-2004 11:33 PM
approx how much hp from home porting heads? Dubz Engine 31 01-26-2004 03:26 PM
