how much hp does a 3/4 in cam add. - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-16-2013, 12:24 AM
I have a 289 withHyper electric flat top pistons with vavle release, 289 crsnk turned .030, rods resized with arp bolts, arp main bolts, melling high volume oil pump, arp oil pump shaft, comp cams 271 h.p. solid lifter cam kit, clowers double roller timing set, 65 heads with stainless 1.90-.160 valves, comp screw in studs and guide plates, double valve springs, roller tip rockers with locks, hardened push rods, intake and exhaust ports gasket matched, arp head bolts, felpro gasket set, 289 torker intake, 725 demon carb, ford dura spark ingnition, ford motorsport aluminum valve covers, flowtech headers, thrush mufflers, mr. Gasket aircleaner and oil breather. Im tryin to get a guess to how much power i have n what size carburetor i need to replace the screamin demon with. I was thinkin a 650
Old 12-16-2013, 01:23 AM
JeffB's Avatar
With the combination of parts you have the Demon should be just fine,why are you wanting to replace it? Maybe you should read this:Demon Fuel Systems - Tuning Tips & Troubleshooting also take advantage of the Tech Support.
Old 12-16-2013, 02:05 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Even with manufacturer names murdered, clowers vs. Cloyes, etc., and assuming hyper electric pistons are hypereutectic pistons, or 65 heads, maybe 65cc combustion chambers?
We need accurate specs to even come near estimated power, it appears you're not sure what you have. Can you elaborate?
BTW, are you sure the crank is -.030?? That's a bunch.
Semper Fi
Old 12-16-2013, 04:15 AM
Banned
Originally Posted by 68NovaSS View Post
Even with manufacturer names murdered, clowers vs. Cloyes, etc., and assuming hyper electric pistons are hypereutectic pistons, we don't know what a Comp Cams "271 hp" cam is at all, or 65 heads, maybe 65cc combustion chambers?
my guess is
65 heads.. year
271 hp cam. would be a copy of the ford r code 271hp 289
Old 12-16-2013, 05:16 AM
painted jester's Avatar
TAKE A KID TO A CAR SHOW
Last journal entry: Wifes 79 comeing together!
? We're GUESSING now?
The message I have entered is too short. Please lengthen your message to at least 10 characters. LOL
Jester
Old 12-16-2013, 05:24 AM
Banned
Jester
well as seen as fords hp for a 65 289 was 271..
it's a good chance.. and maybe the o/p will reply with better info..
if it was a random bunch of numbers, then well. but the 65 and 271 are numbers used by ford for a 289.. used here by chance.. maybe but doubtfull..
you got a better idea..on it..
Old 12-16-2013, 06:15 AM
LOL you don't have to explain your guess to me LOL My post was an in general comment on this thread! Till the O.P. comes back on and clarifies his build!! everyone will be taking shots in the dark as posted by 68NovaSS
LOL Jester
Old 12-16-2013, 08:23 AM
Banned
I'm guessing 17hp. Is their a prize for the closest guess?
Old 12-16-2013, 10:54 AM
techinspector1's Avatar
Wiki Edits: 326
electric flat top pistons with vavle release and a 3/4 inch cam.
Thank you Josiah, you have made my day.
The Following 6 Users Say Thank You to techinspector1 For This Useful Post:
68NovaSS (12-16-2013), AutoGear (12-16-2013), BOBCRMAN@aol.com (12-16-2013), GoFastStripes (12-23-2013), SPEED MASTERS CC (12-16-2013), tapkoote (12-23-2013)
Old 12-16-2013, 11:20 AM
You are quite right tht i dont know what i have. I inherited this truck from my dad who died last month n im trying to figure out what i have n what i need to do if nething. All i have to go on is this list tht he had tht i posted. When i get on the gas it bogs down n trys to die n i was told it was the carburetor. Just want to get it runnin n restored the way he wulda wanted. Ne help or advice wuld b much appreciated.
Old 12-16-2013, 11:23 AM
Banned
That's a tragic story.
He'd probably be more proud if you learned to read and write though. Do that and engines (and everything else) will be a lot easier for you to understand.
Old 12-16-2013, 01:30 PM
jokerZ71's Avatar
Wrench Turner
I would suggest a full tune up before doin much of anything.Getting timing & carb correct afterwards.Those 3/4 cams are hard to predict HP on.Back in high skool everybody had a 3/4 cam & 750 double pumper,& headers.HP ratings were anywhere from 400 to 600,depending on who's vehicle this combo was installed in.When you ask what the lift or duration on that 3/4 cam wuz,you only got funny looks.Nobody wanted to tell their secret grind.
The Following User Says Thank You to jokerZ71 For This Useful Post:
Buick b4 (12-17-2013)
Old 12-16-2013, 02:39 PM
Thank u joker i really appreciate it. Thts some advice i was lookin for.
The 289 is not a really big engine so even a moderate performance cam and smaller 4 barrel are very effective at producing power. The thing will wind well into the 6000 RPM range with the factory 271 horse cam. You'll fine the advertised power was pretty honest. The valve size that is in your heads of 1.9 by 1.6 will tend to push the power curve further up the RPM range. The bigger valves and the cam will make this engine difficult to tune under 2500 RPM, it will want some gears in the rear end and a high stall converter if attached to an automatic transmission. A carb of 600 to 650 CFM will be plenty. The Ford intake is the real bottle neck, to push into power levels around 300 this will need a good aluminum high rise intake.
The high performance 289 and 302 were known to be piston eaters, even with forgings they would bust skirts pretty easily when you pushed power up to the redline. Hyper-eutectic pistons if set up on the tight side of skirt clearance will probably be OK, but if the bore to piston clearance is on the wide side, the rather brittle nature of these super high silicon alloy pistons may fail the skirts. This can also be a problem if the cylinder bores are punched more than .030 inch; this is a thin wall block, if the cylinder wall thickness is too thin they will move away from the piston when loads are applied which makes the skirt to wall clearance act as if it is wider than when measured statically during build up in the shop. So just try to stay out of RPMs above 6000 to preserve a long life for the engine.
Bogie
Old 12-16-2013, 03:25 PM
Awesome!! I really appreciate it bogie.
Best Ebay Add Ever!!! SSedan64 Off-Topic 4 06-11-2011 08:27 PM
Can't add to my journal 31chevy Hotrodders Site Suggestions and Help 4 04-23-2007 09:23 PM
i need help with add on's wrestlingclub142 Body - Exterior 2 06-05-2005 04:51 PM
how much hp does a cam add? malibu68 Engine 5 04-18-2005 03:54 AM
Where`s my add? slider in wa Hotrodders Site Suggestions and Help 8 12-30-2002 04:57 PM
