Advertised 400 hp but made 446 hp.
Hey ,your still reading it,maybe cobalt will read it and answer the question,even if its not relevant to you now that your engine is built or blown up, the rest of us might find the information helpful , interesting,and its a way to get in touch with someone that has experience with what's being discussed,probably the main purpose behind keeping these threads on line.
It's a post from 2009, but the additional info is very interesting, and will benefit those with similar engines today. I'm building a '83 454 from a truck, and swapping the factory peanut heads to Edelbrock oval port aluminum heads. Best upgrade you can make to a smog motor 454 with peanut heads is a good pair of heads and the right cam. The smaller combustion chambers and better flow will increase compression, and develope more HP and torque.
[QUOTE=yankee phil;1674482]Can you tell me the number of the castings on those crate motor rectagular port heads . There are more crate motored trucks here in the junkyards than original equipped ones so it'd be handy to be able to pick out the hidden treasures. I've heard of these crate motor heads but have yet to see a pair,kind if a myth over here I'd like to see proven true.[/QUOTE )
The number on mine is, 6272990 There is also a M-7-3 and in another spot GM1T, Also says HI PERF. All under the valve cover and really easy to see. Dean. |
| The Following User Says Thank You to Dean Pearson For This Useful Post: | ||
yankee phil (05-13-2013) | ||
| rectangle port intake with oval port head | brendawhit | Engine | 2 | 05-06-2009 11:26 AM |
| What rpm is a stock Gen V 454 bottom end good for | Hacksaw | Engine | 1 | 04-20-2009 12:31 PM |
| 454 BBC pushing 900+ hp | Chevy2311 | Engine | 15 | 04-15-2009 11:51 PM |
| 400 Hp Stock Engines-im Pissed! | bullheimer | General Rodding Tech | 22 | 07-17-2003 03:09 PM |
| Stock eliminator | 78 monte | Engine | 5 | 01-02-2003 05:10 AM |
