Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - how much hp and how fast
Old 04-08-2004, 06:42 PM
tm454 tm454 is offline
Tazz
can you spell N-E-W-B-I-E?
How much HP does the stock engine put out? You add on HP for duel exhaust and a mild cam and porting and polishing the heads helps a lot, did you flow the heads? I would guesstimate 350hp give or take a few. Probably 14 in the quarter with those gears. Go to the track with it and tell us what you run. Make at least 5 passes then get back to us with the results.
Tazz
Rat Rods Rule!
