how much HP my engine have? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-18-2004, 08:49 PM
New Member
i try to figure out how much HP my engine have. i am sure your all better that me to figure it out
my cars is a 1979 pontiac parisienne.
the engine is a chevy 305 2bbl. (my estimate 120-140 hp)
i made the following modification all by my self like a big boy.
removed the catalytic coverter (my estimate add 5-10hp)
change the muffler for one with direct flow (add 5-10hp)
and reverse the air cover filter (5-10hp again)
so my estimate give me something like 135-170hp
Old 10-18-2004, 09:10 PM
Ghetto Jet's Avatar
current hot rod: CTS-V
Last journal entry: Lets Get Started With the Improvements
That motor, assuming it's in good condition makes about 170 horsepower to the crank. If the cat was clogged you gained some power, if not then eh, I'll give you 5. Probably 10 for the muffler and 5 for the filter cover. So you should be at about 185-190 at the crank.
Old 10-18-2004, 09:11 PM
Mad Maggot's Avatar
The lean mean donut machine
You're probably about right, I'd say maybe 140 hp. By air cover filter, do you mean the lid of the air cleaner? If so I doubt it would do anything to increase performance. Are you looking to improve the power of the engine at all? If so I have some experience with 305s so I may be able to help you out.
Old 10-18-2004, 09:18 PM
Ghetto Jet's Avatar
What flipping the lid on the air breather assembly? Going from one little snorkel to and exposed element certainly helps a little.
I used to have a site saved that had a dyno result for a stock 305, 80 Caprice. It made 144hp at the rear wheels. Assuming yours made a little less because of the two barrel I put you at 170 at the crank, not wheels.
Old 10-18-2004, 09:42 PM
ChevelleSS_LS6's Avatar
Jeep XJ and a Javelin
Last wiki edit: Compression test
Last journal entry: August 9, part III
Wiki Edits: 7
Get a 600 CFM 4bbl; vacuum secondaries is what I'd do next. If ya need a new intake manifold, get an edelbrock. That's assuming you have money to spend.
I love big cars, good luck on the Caprice. My cousin has an old '80s stule coupe that has a funky rear window (think of those Monte Carlo Aerocoupes form the 80s). Sadly, he doesn't know how to take care of it and it's rusty. I believe it's qite a rare car.
Old 10-18-2004, 09:52 PM
New Member
what i mean for the air filter is that..... aah **** here a picture. it worth a thounsand words. thanx god for my digital kodak a thousand word may be long for me to write bcauz english is not my native langage.
Name:	mini-pic of my engine.jpg
Old 10-18-2004, 10:32 PM
Ghetto Jet's Avatar
I knew what you meant, I run my Caprice with the lid flipped. I notice the difference, even though it's minor.
Old 10-19-2004, 08:01 AM
killerformula's Avatar
Last wiki edit: Carburetor
Last journal entry: Clean up
Wiki Edits: 3
couple of cans of chevy orange duplicolor will gain you 20 horse.
K
Old 10-19-2004, 09:57 AM
Ghetto Jet's Avatar
K
Did you see that motor? I think you might be right. lol
Old 10-19-2004, 03:04 PM
New Member
i knot it look bad but it's run very great. i will rebuilt the car minus the interior this spring. bcauz i must work outside and winter is rough here in quebec. calcium have done a lot of damage over d years . i will take this time to learn much was i can.
Old 10-19-2004, 04:07 PM
70SPORT's Avatar
who cares....its a pile.....170 hp isnt crap no sense in trying to polish a terd
Old 10-19-2004, 04:11 PM
stepside454's Avatar
i relly hat 2pik on sumbodys spellin, bot holi carp datsbad
